BS EN 12665:2011 In Relation To Metal Lighting | on ElectriciansForums
Discuss BS EN 12665:2011 In Relation To Metal Lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
Manich44
Hi,
Can anyone point me in the direction of a free copy of BS EN 12665:2011 Lighs and Lighting.
Thanks....
Mark
I'm not sure the BSI would be impressed!!
Have you tried searching for the European version ES12665:2011 I know with other euro standards you can quite often download it from another country for free where BSI will charge.
Thanks for the reply,
Just started manufacturing iron lighting,lamps,wall lights etc and trying to find out what criteria must be met other than the obvious "must be earthed".
Also trying to find out if I need CE certification if I am only selling in the UK
Thanks...
Reply to BS EN 12665:2011 In Relation To Metal Lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Correction on checking exchange rate: the EVS 3-user copy is 3.8 times cheaper than the BSI "member's half price" single-user copy.
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
