Flat below will have to find a use for the copper coated ceiling decoration they now have.
The incoming earth
Well the sensible people will install earth electrodes connected to the MET of the incoming supply to the building.
The less sensible people will be clipping green and yellow cables down the outside of the building to earth rods.
depends if each flat has an individual supply through their own meter and not one large incoming cable supplying a bemco.
Yes i guess your right ,
Smoke detectors
Intruder alarm
Water heater
Door bell
Cooker circuit, electric heaters, distribution circuits to outbuildings, boilers ........
I reckon if you tried you could easily design a domestic install without a single RCD in the CU.
How each circuit in the bathroom has to be rcd protected
i think you'd still end up putting thbathroom lights on an rcbo, but apart from that you can do it with RCD sockets everywhere and steel conduit in all the chases.
I was just sugesting circuit that I could get away without the use of metal conduit , ie high level mounted spurs but , not sure how you would omit rcd protection in a bathroom , although you could have a frosted glass wall with the lights outside tbe bathroom
But as i mentioned the 18th addition with stop that with all lights requiring rcd protection
18th will require any luminaire circuit to have rcd protection.
Afdd look good but the word "may be used" will mean people will not use them.
Okay so apologies for derailing this one slightly, lets get back on track.
New reg 521.10.202 suggests that all wiring systems shall be supported so that they will not be liable to premature collapse in the event of a fire.
This replaces the old requirements for escape routes only.
Does this mean an end to clipped direct with PVC clips and plastic conduit saddles ? Buckle clips or similar and metal saddles are the obvious solution here, but does anything exist as a retro fit to existing containment systems like dado and perimeter trunking to meet this requirement ?
What about plastic SWA cleats ?
In what way do AFDD's look good?
Just look at the trouble they've caused in the USA where they are mandatory.
There is no practical way to test them, no way to know what has caused them to trip. And they suffer from massive nuisance tripping because the operate when they detect an arc, such as the arc that occurs in any switch or thermostat when you operate it,
In terms of protection from fire, i have come across flame retardant clips and plastic saddles that withstand fire/heat upto a certain temperature. This was whilst working in a firework factory store room. where the fire precautions were obviously very OTT. the saddles were made of a composite material similar to kevlar. I can't be sure what the standard type of cable clips were made of but they were supplied by the design specification team and ready for when we got on the job. Surely something along these lines could be used retrospectively?
OBviously not in that Chinese factory that blew a couple of years ago. Watching the footage of the second explosion and the air movement a couple of miles away at the car park barrier was epic.
Just another thing to make the job more expensive.
According to tony and Darren, most fires are caused by arc faults in high resistant joints so if we fit AFDDs everywhere we shouldn't have to fit metal retainers!
Only joking @davesparks before you berate me!
No, it's another thing to prevent the loss of human life.
Firefighters have died from being trapped in cables which were not supported with fireproof fixings.
Exactly, pf200 enclosed in surface pvc trunking in stairwells across the bulkhead areas (in tower blocks) for smokes, call points, sounders.
That huge explosion and fire in 2005 at Buncefield was much bigger and quite spectacular. supposedly biggest explosion since WW2. i was living in Amersham at the time and it woke me up. I dont think fire rated clips and saddles would have made much difference, neither would AFDD's.
..... how can something we've been doing/using for decades suddenly become dangerous overnight,............
This bit scares me ,must be documented cases of mistakes / failures / near misses .
(Like my ISO man at work , a continous process of improvement (at a cost),documenting mistakes , for areas to concentrate efforts on )
Cost -vs- Benefit . (legal twists pass on responsibility ?)
We may have come from well enginered culture , and are letting things slip ,
and maintanace costs get passed down to next customer .
Eh ??????
What is the crack with upgrading to 18th Edition will my company pay for it amd the regs books? Will they schedule it for when the regs change over or what? I was only an apprentice when it went from 16 to 17
Wishful thinking Hardwired, wishful thinking, unless you are working for a very large company with it's own training budget.
My company will be picking up the tab for the course along with the cost of the new 18th Edition book. The downside is that as a sole trader, I am the company. :(
So the TAX man gets you anyhow , offering taxible freebies to employees ?
Whereas HMRC considers a limited company to be a separate legal entity from whoever owns the company, a sole trader and his business are considered to be one and the same legal entity.
Fees incurred for any training courses that are wholly or necessarily for the purposes of the trade are a legitimate deductible business expense which can be set-off against tax.
BS7671:2018 Proposed Changes
Thread Tags
Tags Tags
changes
hightower,
Dave OCD,
