Soup
Hi all
I'm unsure if it's appropriate to post this on this board but I wanted to get opinions from people in the industry on a sticking point with an electrician I currently have.
a bit of background - I am letting out my flat and as part of the pre-let safety checks I decided to go ahead and get a "periodic test" carried out on the flat - a test under BS7671 on the internal electrics.
The electrician did the report and said the circuits were satisfactory, supplying me with an EICR on completion.
On the report, it stated he was unable to test 2 things :
1) The off-peak water circuit, as there was no power on the circuit due to it being tested during the day. I was fine with this...; and
2) The central heating circuit. I have Flexel Ceiling Heating in the flat and was quite specific about asking him to test this from a safety point of view. He said as there were timers in the circuit he was unable to test this (I have two 24-hour "pin-controlled" timers on the hallway wall).
The central heating point is where I am having the issue. Following further discussions, he said that as well as the issue with the timers, the heating did not seem to be powered as it was being fed from a night-time supply, external to my flat.
This struck me as a bit odd - I know my heating works (a friend of mine went to the flat on my behalf to test it after the electrician had done the BS7671 test and said it seemed to work fine) so I'm a bit puzzled why he couldn't test the heating circuit. Maybe the night-time supply could be explained by Economy 7?
The electrician also said he couldn't work out how to turn the heating on as well - so surely if he had actually turned the heating circuit on (there's a main on/off switch on thermostat in the lounge of the flat) then he should have had some sort of electric current reading to confirm whether it was satisfactory within the boundaries of the BS7671 test?
His final reply to me recently was:
"I offered a ‘Periodic Test’ of the flat’s electrics as prescribed by BS7671. This is a test of the various circuits, specifically earth loop impedance and insulation resistance. This testing does not include appliances, and also excludes central heating (systems) which is effectively an appliance.
The power circuit cable from the consumer unit in the hallway goes straight into the timer boxes and these appeared to be preventing that circuit from being tested. There is no requirement under BS7671 to have to dismantle apparatus in order to test which appears to be the case here.
As I said, all other circuits check out fine, and on the basis that this circuit is of the same vintage, and nothing has been modified, there is absolutely no reason to be concerned.
So if you have an absolutely specific cause for concern about the ‘circuit’, then that would be a separate piece of work, and wouldn’t come under the remit of ‘Periodic Testing’.
If it’s the case that you want a general central heating service/ health check, then this is something that is definitely outwith the scope of periodic testing, and is not a service I can offer."
What do you guys think - is he fair in his comments, or he is simply trying to avoid having to going back to test the circuit again with the heating switched on to see if it would have a different result? He seems like a stand-up guy and the other work he has done for me has been fine to date.
Thanks in advance :army:
