bsen code for switch fuse | on ElectriciansForums
Discuss bsen code for switch fuse in the Australia area at ElectriciansForums.net
H
HUD
dose anyone know bsen code for sp & n 60 amp wylex switch fuse ?
Chris is right, the switch is to BS EN 60947-3, but where it asks for the overcurrent protection for the circuit you'll need the BS number for the fuse in the switchfuse...BS1361, or BS 88.:)
Reply to bsen code for switch fuse in the Australia area at ElectriciansForums.net
There is no homework, and I'll never see these photo again.
You can see the terminals from the top, in any case work has asked me to address the issue,so I spilt some 16mm blind grommets with a bit of ct1...
