Hi Guys
Just first fixing fixing a new build and master BT point needs to be in the basement plant room/ next to rack.
BT incomer is overhead line, coming into property on far first floor corner.
Opposite corner to property from basement - basically a long way away!
Other ones we've done with fibre have been lucky and BT able to come straight in where mast point is.
Question is how does fibre terminate into the building, assuming they'll take to the nearest point on first floor and fit some 'sort of box' ?
Do I run a cat6 to basement from 'BT box' so they can then use this to bring master point to basement ?
Hope that makes sense & apologies for my terminology
Cheers Sy
Cheers Sy
