Hi Guys, As some of you know, I'm doing a new build house. I wanted the new intake Master phone point to be sited in an internal cupboard position. Property is block beam, suitable u/g ducting installed under the block beam with draw rope. apparently I'm told I can't have the BT phone line installed there. I've got to have an unsightly grey PVC capping where the cable will emerge from the ground on the outside brickwork at low level and the BT cable drilled through wall and Master point other side of wall. any one had similar dealings with BT? I can't think why it is not acceptable with a phone cable. I can understand safety issues if it were to be gas or DNO's cable.
