BT point | on ElectriciansForums
Discuss BT point in the UK Electrical Forum area at ElectriciansForums.net
soulman
Durham
Hi second question of the evening. A master bt point wires to AB want to replace for a master in chrome do the wires go to 2 & 5.
Cheers
Cheers
If your master socket has any extensions connected to it then replacing the BT NTE5 may cause some problems if your line develops a fault as the NTE5 acts as the external line test point
Yep master 2 and5, slave 2 5 and (3 ring wire)
Only if you want to reduce your broadband speed due to the interference it causes and if you have a faceplate type ADSL / vDSL filter then most of these disconnect the ring wire
Reply to BT point in the UK Electrical Forum area at ElectriciansForums.net
I know it was a few years ago when LED was mor in its infancy but we looked at a job that had designer flo light fittings in a big bar. The...
Try to use a catenary wire for better support for your outdoor cable. I'd recommend TP-Link ceiling-mounted access points, which are good options...
    • Winner
