Bug-ger me | on ElectriciansForums
Discuss Bug-ger me in the Australia area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
Found this today. customer called because the lighting MCB tripped when he switched on the outside lights
I guessed there was a hic up.
Click on the insert image symbol, then with it on the "From Computer" tab click the blue select files button at the bottom and find where it is located and up load.
nope. i click on insert image and all i get is a pop=up saying this site says enter url. http something. if i click ok or cancel it just goes back. nowhere does it say from computer
Try and do it from the quick reply as the advanced post is more difficult.
looked at your diagram. don't get that on mine. then took me this long to reboot and get back. trtied again and got your diagramGEDC0071.JPG
Reply to Bug-ger me in the Australia area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
