Builder safety worry | on ElectriciansForums
Discuss Builder safety worry in the UK Electrical Forum area at ElectriciansForums.net
UK
in 2003 i engaged a builder to extend my property.
1-when I asked for 3 light switches to control 1 light, it took him a week to find out how to do it....he ran multiple cables , just in case, until he found out how it should be done...
2-he fitted a consumer unit, but immediately it kept tripping every time an appliance was used.....this went on for many many many hours, eventually he disconnected some protection within the box, think it looked for difference between live and neutral, he said it wasn’t needed anyway, after 2-3 years it suddenly started emitting smoke.....I called an electrician and he said it had been wired up wrong and replaced it completely...
3-today I removed some flooring and skirting board in my spare room, for decorating and a plumbing change, but found he had used a domestic light switch as a junction box below the floorboards and behind the skirting I found a 2.5 cable supplying a socket running behind the skirting, it had a connecting block joining it to another cable, which was buried into the floorboard.
In my builders defence, he once said to me, when I enquirer about an electrical issue “ well I am not an electrician” says it all I guess, I should have said, get a real one then, but at the time tensions were high and the the extension was taking far longer than expected and costing a lot lot more, so couldn’t afford to rock the boat......I wonder what other surprises await me in the future.......
Is my experience typical ?......scares the hell out of me
Thanks Alex rybak whereever your are
[ElectriciansForums.net] Builder safety worry
wor
that why part p was brought out to stop f88king t**ts killing people .
worked well didn't it? still got bob the builder/kev kitchen/wayne wet-pants/ diy dave/ "doing electrics".
ah, the wonders of "having the builders in"! No, my friend, you are not alone...far from it!
You have been lucky, having found these problems before a major catastrophe. OK we all have our "Builders disaster" story...fact is, they get there electrician mates in, pay them buttons, and off they all go to the pub, splitting the cash...
I had an extension put up a few years ago. I am fussy, and told them so..."Do not take this job if you don't want me on your back" I said...
Every evening when I got home from work, I would ask them to undo the wiring they had done, and spent ages typing notes (OMG, I hear you experienced guys say!) but next evening...ignored! I asked the chief "electrician" why he had undone my telephone cabling and junction boxes...he said, "you don't need them there, they are fine over here"
and when the stair goes in over them..that'll be fine? Perfectly accessible? He said he didn't know about the stair...job and finish, get the cash and go...
I sacked him... gave him a week to finish off...and 3 weeks later, as I was fixing the hall flooring ready for the carpet fitter, I looked under the floor to see the 2.5mm T+E wrapped a few times round the hot water feed from the CH boiler...
So, paranoid? Me? I sympathise with all you proper professionals out there, but the cowboys are killing you, and that is why, DIY'er that I am, I am glad to be a member of this forum where expertise and common sense rule the roost...
I love electrics, have learned so much from your banter, but I do know my limitations...however, I also do know a "proper job" and it is heartening to see on this site that the vast majority, rather than going for the cheapest fix, advocate the "best practice" route, and a few pence on the job is not an issue.
Builders?
New builds?
Cheap parts?
UGGH!
Rant over....
Wasn’t just the electrics, found almost zero insulation on the 1/2” copper piping, was run so close together I barely managed to squeeze some of the thinner foam insulation as far as I could reach.....when I took out an electrical socket, the piping from the boiler could be seen in the cavity again no insulation.....but on the plus side I do get nice warm walls and floors OMG
I often worry about buying a non new house in case of DIY muck ups, but builders can be just as bad....
Had no end of rows with Alex.....I started a builders book, where each evening I wrote any concerns / expectations, he was meant to respond each day....a response only happened only once or twice in the year.....was a 3 month job, don’t get me started on the roof.........he was going to hire a professional roof tiler, but was too expensive, so done it himself “ how difficult can it be ?”
The roofer who came round said the roof joists were not spaced correctly.....” doesn’t know what he’s talking about says my Alex.....OMG
i though roof joist spacing was automatic these days. a lego roof truss kit ready assembled so even the roughest builder can get it right, or am i dreaming?
Reply to Builder safety worry in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
