Hi I am looking to build an infrared sauna something similar to this:
I have the six infrared bulbs which are 250wattage and 120V. Here:
GE Lighting 37771 R40 Heat Lamp, Red, 250-Watt, Incandescent Bulbs - Amazon Canada - https://www.amazon.ca/GE-Lighting-37771-Heat-250-Watt/dp/B000PSJNFK/ref=sr_1_8?dchild=1&keywords=GE+infrared&qid=1617240451&sr=8-8
I am a bit lost with the electrical part. First the bulb sockets. I was looking at the sockets below (see link) on amazon, they are 660 wattage, 0~250 Voltage, heat resistance up to 150℃. I am wondering if they would be okay ? I assume they would be okay for the 250watt bulbs as they are rated 660w. Thoughts ?
DiCUNO E26 Vintage Edison Light Bulb Socket, Retro Edison Black Lamp Holder, Pendant Light Medium Screw Base, Maximum Wattage 660W, UL Listed, 6-Pack: Amazon.ca: Tools & Home Improvement - https://www.amazon.ca/dp/B089N4YSYT/ref=sspa_dk_detail_1?pd_rd_i=B089NH9NH3p13NParams&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyRk4zQlNRNTY4RlpBJmVuY3J5cHRlZElkPUEwNzI1NzAxMk4wVFYxNE0xRThENiZlbmNyeXB0ZWRBZElkPUEwMzQ1NjQzMVlPUjJHQzdCQkwwMyZ3aWRnZXROYW1lPXNwX2RldGFpbDImYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl&th=1
In regard to the wiring, of all the bulb sockets together. Would there be 3 wires from each socket, so three screws on each bulb socket ?
Hot wire (black), Neutral wire (white) and ground wire ? How would all six sockets wire together ?
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
