8yf13l0
Evening all.
Note sure about this one:
I have a job of new circuits to install for a new domestic extension - nothing fancy.
It has a ensuite shower / toilet on the new install, 2 walls of the en-suite are internal to the extension, 1 wall backs on to next doors extension (touching), and the final wall backs on to the shared car garage - also note the en-suite has no windows.
It has been deemed that an extract fan is required but the location and varous access/space restrictions dictate it to go in only one position - which is on the wall (Zone 2) which backs on to the shared garage where the fan would be sending it's exhaust - not ideal. However this design principle has already been approved by the building controller on the grounds that the fan "has a filter on it".
Now the part in which I am getting stuck is trying to spec the correct fan for the job, both suitable for zone 2 and with built in filters - but the internet does not appear to reveal much options with regards to additional option of filtration.
Has anyone has this scenerio before and familiar with any makes of fan for the job?
Could I get away with a off the shelf zone 2 fan and stick some filter media in the discharge grille on the garage side?
Before anyone asks, I cannot go up and over with in-line fans as the ceiling timbers make this particular option unachievable.
Any suggestions anyone will be much appreciated.
Cheers
Jamie
Cheers
Jamie
