building inspector not happy!! | on ElectriciansForums
Discuss building inspector not happy!! in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Afternoon all..
I have recently been asked if I would sign off a new installation (large new build house) that I had not installed, I said 'no' and explained that I could supply an EICR. Even after a brief look around I could see a number of problems.
The building Inspector has said that he is not happy with an EICR and is going to 'have a think' about what to suggest.
Being new to this industry I wondered what you guys do when this situation arises? I.e new build where the electrician has walked out for whatever reason so the work cannot be supplied with a EIC and the Inspector is not happy with an EICR from a third party?
Cheers..
Theoretically he could ask to have the work ripped out and re installed and an EIC issued.
But normally an EICR is accepted, no matter how bad things look, at least if any faults are identified then they can be rectified and if the results were really bad then the rip out and start again is always an option.
As Des says down to BC to do their job.
Did you find out why the original sparks are gone?
Could be a money/payments due issue and you are making it easy for the builder to continue to not pay the original.
Not saying this is the case, just, did you ask?
Boydy
Have you ever seen that happen Richard or is another solution normally found?
Boydy
I'm more there helping a friend who is an electrician so he is dealing with the developer, he did say that he met the electrician who did the work and that that was actually the 'second' electrician to come in, so goodness knows what happened to the first.
I asked him to find out why the 'second electrician' is not offering an EIC but he didn't ask, I'm guessing the chap isn't registered and neither is my friend anymore (more industrial/commercial).
Thanks for the replies.. I'll be interested to see what the Inspector says!
If the truth be known, probably no spark involved, all installed by the builder with the help of a couple of his painters!!
Thats kind of the feel that I'm getting. I think the developer just expected to pay off someone to sign it off.... he's very well off and made it clear he wanted it signed off quickly, so I expect he's not too happy with the current situation!
I wonder if the BC bloke has spotted some show stopping work and isn't happy because it's so bad....
- - - Updated - - -
Normally they don't give two hoots, drink a cup of tea, check there are 498 smoke alarms, run hand along plaster and leave
Do yourself a favour and walk (run) away.
If you get involved with a "well off" developer at this stage in your career you will eventually be sucked in ££ and blackened. Think dance with the devil/playing with fire.
Boydy
HHD - look into a process called regularisation. Many BC departments have this for exactly this kind of situation. I can send you a pdf of how the council near to me does it. Costs a bit though ~ £300??
EDIT: the pdf would be completely free...!! The 300 squid is the council's exorbitant charges!
Reply to building inspector not happy!! in the UK Electrical Forum area at ElectriciansForums.net
Here the BPG#4 is useful, it is not a statutory document at all, but it provides good guidance as to what can reasonably considered as C1/C2/C3...
N
New build flood The bottom house of our new build flooded, clear clean water with no smell or noise to indicate a burst pipe and it was a large...
Nic161
N
