J
jimmymac
Hi everybody, somethings been puzzling me, today i went across the road to a neighbours house cos he said he was having a problem with a socket not working. The socket in question is in his new extention which was completed around four months ago and the socket never worked in the first place. Upon inspection i found that there is no power at the socket but the breaker is fine. The cable dis-appears into the wall and through to below the new extention, i couldn't go any further because this would mean lifting floor boards and he has layed laminate flooring and he didn't want me to go to all that trouble as he said the outlet doesn't get used anyway.
What i can't understand is, if he informed the building inspector that signed the whole job off, as he says that he did, then surely the inspector has duty to do something about it?? (how can the circuit have been tested if there is a break somewhere?)
It is my understanding that the building inspector has a check list to work to and one of the items on the list is that everything functions properly??
