Building regs and fans in kitchens. | on ElectriciansForums
Guest viewing is limited
Discuss Building regs and fans in kitchens. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
5544
Regarding a house re wire. Just checking, but does a cooker hood expelling outside cover the issue of having a fan in the kitchen. Assume it removes enough air.
Reply to Building regs and fans in kitchens. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I’ve not even had the time to remove the board cover at the moment still busy trying to sort out everything else wrong with the build! Will post a...
The white is the neutral. The black is hot to the light, brown is hot to the fan… (or other way round) I did this myself once, but it was in...
Recommended Sponsor News
Hi everyone,
