Building regs for consumer unit | on ElectriciansForums
Discuss Building regs for consumer unit in the UK Electrical Forum area at ElectriciansForums.net
O
Olijay2017
We are buying a newbuild property and due to the regulations, we are told the consumer unit needs to go in the dining room (as boxes are on the external wall in that location).
As the room will be painted dark grey we want to hide the box inside a cabinet by removing the back from the cabinet and pushing it against the wall. The door of the cabinet will then give access to the consumer unit.
For this to work, we need the consumer unit to be 500mm from the floor in the dining room. We are being told that regs state the minimum is 1.4m.
Is this correct or are we being misled?
recommended height is indeed approx. 1400mm, however, if you are buying a new build house, get the builders to put it somewhere else, cost is minimal compared to the cost of the house.
Thanks for the quick reply. We are being told that the external box MUST be in the specific place it is on the M&E plan and that the internal consumer unit needs to be very close to that. Am I right in thinking the meter box has to be placed in a specific location that is out of the builders hands?
meter box is generally sited according to your DNO's requirements as they are responsible for getting the supply to it. however, the Consumer Unit can be almost anywhere in the house though additional fused isolator may be required. ( downstairs toilet is a favorite location with many builders).
Having a consumer unit (CU) located some distance from the external meter box, is not unachievable, just needs a few extra things to be installed. Its better to have a CU fitted where it can easily be accessed for maintenance and resetting 'fuses' etc, than where its more convenient for your builder.
We are being told that according to new regs, a fused isolator cannot be used?
To locate a CU some distance from the meter box DNO's may require a switch fuse (i.e. most DNO's would require one over distances of 3 metres). The example I gave in #8, would conform to the 'new' regulation in amendment 3 BS7671 (reg 421.1.201, within domestic households, consumer units or similar switchgear). The DNO's may not like such a large device in 'their' meter box. However, there is some dispute that such devices installed in an external wall meter box, does actually require to be A3 compliant.
A switch fuse could be located in the meter box, with the DNO's permission/agreement.
Oh really? I am starting to feel like the builder is just fobbing us off then. So we could potentially have a switched fuse in the meter box along with the meter that would allow us to take the consumer unit to anywhere in the house as long as it is downstairs? Thanks a lot for your advice on this one by the way.
Reply to Building regs for consumer unit in the UK Electrical Forum area at ElectriciansForums.net
IMO Better to do something about those ignoring regulations first! Current system is like having a speed limit but not enforcing anyone without a...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
