burglar alarm removal | on ElectriciansForums
Discuss burglar alarm removal in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
T
tickover
Hi Guys
New to the forum. I was wondering if there is anything special I need to do to remove a ADP Alarm system someone has asked me to remove, Never really worked n alarms systems before so any advice would be greatly appreciated
Cheers
Tickover
only thing is when taking the bell box from out side make shure u take the siren wire out or the siren will be going till the battery runs out
and make shure the feed to your pannel is definatley dead dont wont no holes in the side cutters now
Firstly set ladders up to get to bell box.
Then kill the mains to panel and remove battery from panel, Bell will probably be going off now (if alarm was any good anyway). Now run up the ladder with your fingers in your ears being carful not to fall off. Whip the cover off and try to disarm siren, if you fail or the noise is getting too much. Remove it from wall and throw down onto concrete to break it. If that dont work jump up and down on it for a bit.........if that dont work put remains in a bin full of water. it will shut up eventually. lol
All the while keeping a professional look about you.
There are other ways to silence bell boxes but they are trade secrets to us (past) alarm engineers.
Reply to burglar alarm removal in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Oddly enough, I do actually have a wind-up megger! It sits on my curiosity shelf beside my AVO which, sadly, I can't get to work despite buying an...
For my hapeneth and learnt from hard recent experience, the term LED transformer and driver tend to be used interchangeably, when they are...
