I have been following a couple of threads 13634-regs-rcbo-s by wire the world and 13628-rcd-testing by king.
A job came in today to do a PIR on a property that I worked at some years ago and I’d like your opinions.
The cutout is in a basement garage, feeding a cu which is high up in the ground floor wc above.
If I remember the cutout position correctly that would make the tails about 3.5m – am I right in thinking that anything over 2m requires a Switchfuse?
Unless I am lucky and the tails are up the cavity, they won’t be buried deeper than 50mm.
30mA RCD in the garage is impractical so I guess its chop out for steel conduit or SWA unless anyone else has any bright ideas?
