burnerr not firing from time clock, | on ElectriciansForums
Discuss burnerr not firing from time clock, in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Northern Ireland
as above oil burner not firing from timeclock but is when you push manual button on boiler itself..
i dont think has anything to do with wiring now, there is a part within boiler not working and i dont know the names of the parts....
any help appreciated and more info il supply if can...
Is the time clock knackered? What type of time clock is it?
I had a similar thing in a church earlier in the year and once I replaced the very expensive sangamo time clock it worked fine again.
It does sound like a faulty relay in the timeclock as the manual over-ride may bypass the relay to give permanent supply out when calling for heat, easy way is set the timer for 1min into future then so if output switches on when its reached its time, also check connections like live loop etc are all tight if external to clock.
Have you checked for power at the connections at the boiler itself? If you're getting 230v on the switch live when the clock is on, then you know its something in the boiler.
Reply to burnerr not firing from time clock, in the UK Electrical Forum area at ElectriciansForums.net
Try disconnecting the "central heating off" wire from terminal 2 and insulate it (eg Wago connector or choc block or similar) and tuck it out of...
2 3
4K
