B
Boberto
Is the most common cause of this problem a loose connection? I came across a burnt out neutral wire on a 100A DP main switch earlier. It was hard to tell if it was loose as it was charred and burnt so bad I couldnt tell! The burnt wire was the 16mm incoming neutral.
The establishment is a fast food take away. There are a number of 100A DP switches supplying flats above, the basement and the main shop area. The isolator where the problem occured was supplying the shop which is in use 7 days a week 10-12 hours aday. Current = 25A approx when checked with clamp meter however when the deep fat fryers kick in the current drawn was showing around 60A. That is the only appliance pulling current of any size. The rest of the shop consumes of grid lighting and a couple of ring finals which supply juice to chest freezers, the till, fly exocutor etc.
From the isolators 16mm tails supply the consumer units located in basement, flats and shop (10-15m distance approx). The main fuse is 80A and the 16mm tails are installed in MT4 trunking to the sub mains with main earth.
Am I missing something? Could this merely be a loose cable connection or is there a chance this is a loading issue. I was under the impression 16mm tails fine protected by a 80A main fuse providind the tails are clipped direct of installed in correct spacing factor trunking?
Advice....?
Advice....?
