G
Gerry24
Had a call out to look at a burnt 3 pin plug on a convection heater. Just a standard 1363 plug with a 13 A fuse. The line pin was burnt. The customer had removed the cable from the plug so couldn't check to see if a loose connection. Cable seemed fine, no scorching or melted insulation. Checked socket, also fine no loose connections etc. However the heater had been plugged into a digital timer at the time of the fault although the timer still seemed to be working OK. Any ideas what could have caused the fault?
