The O.P posts on LOTS of other forums, usually car related.
He's,,, unusual in his approach to things sometimes
Agreed! However, this isn't particularly straight forward.
I should have probably put more detail into my initial post.
I'm currently in the middle of purchasing a new house. It's a 3 year old 4bed detached with a separate garage. Earthing system is PME/TNC-S and there's no bonding required in the outbuilding(s) concerned.
Ideally I'd have bought something older and gutted it myself and made it how I want it but my Wife is pregnant so I don't have that luxury.
I'm also maxing myself out on the mortgage of this out on the basis that it's only going to get easier.
I plan on making the current garage into a small workshop and the current 20A supply isn't going to work for me. Therefore I need to do what I can with what I have. And what I have is quite a lot of galvanised conduit & trunking along with 6491B.
My plan is to have a 6A circuit for lighting, a 16A circuit for heating and a 32A circuit for power all fed from individual RCBO's in the house consumer unit.
I also need to get data out there. Ideally a fibre or at least a shielded Cat5e/6.
I don't intend on doing anything dangerous. There is absolutely nothing wrong with using well constructed metal containment as a CPC. I personally find the installation of CPC conductors in a metal containment system where they are not required totally wasteful and makes for sloppy containment installation.
The issue here is ensuring the conduit underground will last. I have an old Land Rover Defender so I have all sorts of primers, paint and underseal about. Weirdly I also have a 100m roll of 32mm 2:1 heat shrink which would be ideal to cover a 25mm conduit.
This isn't going in for at least another 6 months. Maybe it's worth prepping a small off cut of conduit and burying it underground and seeing how it holds up?
I'll also be putting up a shed in the back garden for the lawn mower, bikes, strimmer etc and will be planning on putting a light and a socket out there using the same method.
