Busbars and cable clamps? | on ElectriciansForums
Discuss Busbars and cable clamps? in the Commercial Electrical Advice area at ElectriciansForums.net
Strima
V.Nearly Esteemed
St Neots
Anyone know where I can get a busbar and some cable clamps from similar to the PDF below? Needed for 48 VDC neutral bar as someone has bodged up some earth blocks and we can't terminate anything bigger than 10mm...:(
screw_busbar_terminals_zb_series_1159041-630932.pdf
  • screw_busbar_terminals_zb_series_1159041-630932.pdf
I think something on the forum is redirecting links this has happened a few times now.
This is the pdf just for the busbar clamps section.
Awesome, luckily Farnellls are on our approved suppliers list.
Reply to Busbars and cable clamps? in the Commercial Electrical Advice area at ElectriciansForums.net
none at all.... and the rcd trips within specification... test button operational.... nothing to suggest there's a problem until you take the...
I think a 3 legged breakout boot would be your best bet in the circumstances.
davesparks
