Hi, I've read a few threads about buzzing dimmers on here but still have a query and would like some advice please.;
Customer has x4 low voltage downlights with electronic transformers for halogen lamps fitted to each downlight. These transformers are 60VA each (Saxby model ET60T-R 20-60VA 4.9amp max selv) and a dimmer switch is fitted. Problem is that the dimmer has a very noticable buzzing sound, not so much when full on but when dimmed it is very noticable.
I have changed the dimmer 3 times already, 1 was a 250w rating, then a 400w and last I even put on a 1000w to see if that would help but still very noticable buzzing. I also have changed the lamps from a 50w GU5.3 to 28w lamps to reduce the load but no difference either?
For working out the load is it correct to take the transformer rating at 60VA and if so 4 downlights should still be well in range of a 400w dimmer? even after a 20% de-rating.
Also, before I left I put on a 250w trailing edge dimmer and there seemed to be a reduction in the buzzing however the lamps flickered a lot. I have read somewhere that for electronic transformers to work they need to be loaded to a minimum of 70% of their rating when being dimmed? Am I wise to put back in the 50w lamps and use trailing edge dimmer in that case?
Also, the original dimmer could have been poor quality however the last one I bought where £25+ each so not bottom market. It is also fed by a 6amp type breaker.
Any advice and help would be appreciated please.
