Morning chaps!
Advice needed please. Is there a tried and tested combination of manufacturer(s) for reducing the annoying buzz from dimmer connected (dimmable!) LED lamps?
In the particular example I am having right now, I have 5 lamps on one dimmer switch, 3x ES and 2x SES. One or more of the lamps routinely makes quite an audible buzz. However it tends to be random which one of the lamps is making a noticeable buzz. Client has tried various combinations of lamps including cheapo and expensive.
Circuit checked and passes insulation testing (>2M), R1+R2 is as expected for the length of run of 1.5mm2.
The dimmer itself does make a low buzz, but they all do, right?
Anyone experienced this before?
Thanks in advance
Thanks in advance
