Buzzing socket | on ElectriciansForums
Discuss Buzzing socket in the Australia area at ElectriciansForums.net
Dionne01
Hello all. One of the sockets in my baby's bedroom is making a fairly loud buzzing sound when an appliance is plugged on.
Is this dangerous? And how easy is the problem fixed?
Thanks and any advice greatfully received.
Dionne
is this any appliance thats plugged into it thats making the buzzing sound
if so could be a fualty socket at a guess the plug isnt making a good connection and arcing but this is just a guess
id replace the socket and as for danger id say its a possible fire risk
or could be as simple as a loose connection
but cant say without seeing it
Thanks all. It happens with all appliances but strangly only after they have been on for over an hour or so.
Anyway, I'm going to replace the socket tomorrow. Hopefully I'll still be here to be able to report back tomorrow.
Thanks again
Dionne
Reply to Buzzing socket in the Australia area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
Throw it out, not worth trying to mend because if you refit cover you are supposed to check there is no leakage of microwaves with a gadget, if...
