DurhamSparky
View attachment 11638View attachment 11639View attachment 11640View attachment 11641View attachment 11642View attachment 11643View attachment 11644View attachment 11645View attachment 11646View attachment 11647
handful of joyful pics....!!
any way!
went to change CU, Do earthing ETC and what do i find lurking in the Meter under a sealed lid (sealed by NEDL) yup a nice piece of twisted copper.... grub screws missing and heat damage to the meter enclosure...!!
PAP!!! ive pulled the fuse and cut all seal.... oh well stand by for -------ing from NEDL and E-On
any way i ring NEDL and conversation goes a little like this
ME-Hi blah blah blah, ive pulled your fuse on a upgrade job due to damage to CU and consumer tails...!
NEDL-oh right what's the address... blah blah blah, so you pulled fuse and discovered a meter bypass etc..
ME- Yes that correct, i need the supplier info so i can contact them as meter is damaged due to there interference.
NEDL- Yes that fine, E-On on blah blah blah...
ME-what about the main fuse i pulled and cut seals..
NEDL-Are you a registered electrician...
ME- Yes... im with Elecsa
NEDL- Thats fine, you did what you needed to do so don't worry.
ME- So you turn a blind eye to electricians carrying out works that require disconnection.
NEDL- In a roundabout way as there is no way in ensuring safe isolation. only registered electricians though so we have traceability.
ME.... PHEW...!
Meter Plus Revenue Protection engineer came out less than an hour later after ringing E-ON and installed new meter, installed an isolator i provided and resealed up supplier side and thanked me for my assistance.
we had a bit of chit chat as we bumped in to each other on another job i did where tenant took a sledge hammer to equipment on leaving his house.. lol, he gave me direct office number for future reference. he also told me that as long as a registered electrician carry s out work they not overly bothered about resealing equipment at next site visit.
i was even asked if i could forward my findings to the office for investigation and got a big thank you!
AT LAST SOME SENSE FROM A DNO AND SUPPLIER!!!
any way!
ME.... PHEW...!
