C.s.a. | on ElectriciansForums
  • Thread starter bf03yvd
  • Start date
  • Replies 23
  • Views 2K
Discuss C.s.a. in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
B
bf03yvd
Can someone explain what a Cross Sectional Area does please ? New to this, so i'm at the idiots guide stage lol:seeya:
The cross sectional area of a wire determines its size and therefore is a determining factor in its current carrying capacity.
Hey, are you in training? if so my advice would be to ask permission to gain entry to the trainee area, you may get a bashing in the open forums.
Um...it doesn't do anything, it just is. It's the surface area of a slice taken through a conductor. So if your conductor is a copper bar which has a square cross section and the square is 10mm on each side, you have a 10x10 = 100mm squared cross sectional area. Normally we're talking conductors which are circular in cross-section, or multiple conductors stranded together. A single circular cross section conductor with a diameter of 1.78mm you can work out has a cross section area of 2.5 mm squared. Seven of those stranded together would have a cross sectional area of 17.5 mm squared. And so on.
The relevance of it is, the more conductor cross sectional area there is, the less resistance it puts up to the electric current being pushed down it, and so the less volts it drops along its length as the current passes, and the less it heats up because of the current. It's like a water pipe - the bigger the pipe, the more water you can get down it with less pressure loss.
But whats your question? We can help you if you dont tell us what you want to know about the cross sectional area. Its a big world out there .....
Oh well I have scanned the page now!
[ElectriciansForums.net] C.s.a.
hmm. what does c.s.a. do? takes a bloody great chunk of wages to keep the ex. in booze and smokes. kids walk round in rags.
So are younow saying that there are 2 things you don't understand
1. csa
2. forums
now i dont understand what you dont understand, if you understand what i mean!
So does that mean, if I fit out my house with tiny bore water pipes I'll get free hot water?
Save a frigging fortune on the gas bill!
Reply to C.s.a. in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
It was purely an off the top of my head example, but I'd say - accessible live parts C1 - inaccessible live parts C2 - 10 feet up in a locked room...
@DefyG is right... I'm not fully sure what your boss is after as when doing single line diagrams I usually show the whole installation. Anyhow I...
