R
rob1967
Hiya guys, Whan you do a Board change What do you put on the cert? I have done a board change and then tested every circuit, Do I put all the readings on an Installation cert or a PIR cert?
Discuss C u change cert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I would also have done a P.I.R prior to the board change to avoid any nasty surprises .
I would do a P.I.R first cos when I change the board I dont then want to be faced with unforseen problems like.
Open circuit protective conductor continuity
Open circuit ring conductors
Borrowed neutrals [ Specially if upgrading to RCD Board ]
poor insulation resistance [ Specially if upgrading to RCD Board ]
etc. etc.
Better to find out beforehand then no problems with client
Yes Chargeable ,but an All in price job.
etc. etc.
similar to what I do mate..... do all your tests first, apart from Zs's and RCD then once CU swapped and switched on you 'should' have no issues, then it's just a case of doing your Zs's and RCD'sI would do a P.I.R first cos when I change the board I dont then want to be faced with unforseen problems like.
etc. etc.
Reply to C u change cert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
