C/u inside garage - needed or not? | on ElectriciansForums
Discuss C/u inside garage - needed or not? in the Australia area at ElectriciansForums.net
kevben
Does a detached garage neccessarily require a consumer unit ?
Is a 16A radial installed in 2.5mm 3core SWA (protected by 30mA RCD @ Main C/U), sufficient and compliant?
Circuit only supplies 1 x light & 1 x twin socket.
Came across this today quoting for something else and the customer asked the question.
Personnally , i would rather the cable be bigger with C/U supplied. However, replacing SWA would not be practical due to block paving etc...
Would like to give the customer a definative answer, cheers fella's:)
Thanks for that Jason :) Yes there is a switch spur and it does have a 3A fuse.
Again the Forum comes up trumps, being able to bounce off others guys when your on your own is a great help, cheers.
I have seen loads of outbuildings wired like this, and i agree with Jason.
Reply to C/u inside garage - needed or not? in the Australia area at ElectriciansForums.net
