A
aaelectric
Evening all,
quick one i dont normally do. had a look at a porter cabin in a waste land, there were around 3 spread over 100m2. Supply coming in to the site is a tncs then this feeds meters and a small DB supplying the cabin. cabin is concreted in. so would this count as a permenant site. the earth from the 16mm swa is being used in the cabin db which has a 30ma rcd main switch. water is plastic pipes. does this need an earth rod also. steel feet have been earthed to cabin db. they want to add some lighting but just wanted to make sure as i thought i had to be tt.
