W
wade88
Morning fellas,
Got two military style, temporary storage cabins to wire up next week. They are mild steel, wooden floored, 4m x 2m x 2.5m high cabins. Only need one double socket and one fluro plus switch per cabin.
Now they are not joined, but are set apart by about a meter and are located underneath some standard pallet racking where they are being used as a chemical store, and a publicity store. they are roughlocated about 5 meters away from the nearest supply DB and the gap from DB to racking needs to be bridged with some aerial mounted trunking.
The plan was to install a 5 way, metal clad to the nearest cabin external wall, fed by some 4mm SWA (42amps) on a 32amp type B at supply board. Then two x 16amp 30ma radials for each sockets and 2 x 6amp mcbs for the two fluros. Single entry through each cabin via roof into 2 inch trunking then make off to socket, switch and light once inside. Cable tray bridging the gap between the cabins housing the cable.
Question is, i am planning on just using 2.5mm and 1.5mm arctic flex, as i have an abundance in the store, but hate flex as i can never get the bugger stuff neat in the board as it has no rigidity but don;t feel it necessary to really use anything else.
Thoughts?
Thoughts?
