J
JohnP1
Hi all im new to this forum and im looking for some help.
I need a 63kw 3 phase supply to run a machine in a commercial building,
the cable run is 25 or 30 meters roughly.
I was going to run in a 35 square cable to the machine and there is an existing isolation breaker at the main mcc with 3 x 63amp fuses in it,
the tails feeding it look like 50 square and there is no rating on the switch!
I should be well covered if i change the fuses to 100amp per phase?
Cheers,
John
Cheers,
John
