cable and celotex | on ElectriciansForums
Discuss cable and celotex in the Australia area at ElectriciansForums.net
A
ab1978
hi
i know your your not suppose to run t&e in contact with polystyrene cause of the chemical reactions over time, but what about celotex and plasterboard with insulation backing? can't find anything written down. been to look at a rewire and the loft has celotex between joists and some of the external walls are to boarded out in it. any advice on this would be great?
yes i know about factors applied i'm just worried does t&e react in the sameway with celotex as it does with polystyrene? my only worrying is like with the loft where cable goes to pendant through celotex?
Celatex dose not contain and chemicals which react against pvc , expanded polystyrene does:D
But to be honest this information was issued in relation to the foam pumped into cavity's
hi
Hi, I have just joined as I have a question relating to your posting which does not appear on any thread I have searched. To add insult to injury I have failed to find our how to start my own first posting!
Anyway I too am in the process of doing a loft conversion and although I have the latest regs I believe there are very new regs regarding cabling in wall and ceiling insulation. I am using Celotex with a 10mm air gap above the celotex between rafters. The regs I have still state clipping cable above the insulation is OK, but I wonder if this is still the case - can you point direction please.
"sparkbuild"
Reply to cable and celotex in the Australia area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
