cable behind polystyrene plasterboard | on ElectriciansForums
Discuss cable behind polystyrene plasterboard in the UK Electrical Forum area at ElectriciansForums.net
Evening guys.
T&E with plastic capping. Is this ok behind polystyrene plasterboard or does it still require to be tin? Getting conflicting messages from the suppliers.
Regards, chris
They changed the chemical makeup of the polystyrene used for building BS insulation purposes many years ago now, because of the plasticizing effect on cables and some types of pvc pipe. It shouldn't now be a problem, though many are still not convinced!!
Reply to cable behind polystyrene plasterboard in the UK Electrical Forum area at ElectriciansForums.net
This charger doesn't support rear entry from the looks, only bottom entry, hence that. Unless they make a white sheathed SWA, I would still need...
