Cable calc help | on ElectriciansForums
Discuss Cable calc help in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Mark.W
Swindon, Wilts
Evening guys!
Was wondering if you good sirs could be of assistance?!
We are installing a 250kW PV system in the next few weeks and I need to size the feed!
The run is about 400m laid in the ground and as stated is 250kW on a 3phase supply!
Many thanks
Mark
Reply to Cable calc help in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
If your using 35mm or 50mm use 2 core SWA and use the armour as the earth, it'll cut down on price. I know people will comment on this but the...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
