Cable calc verification please | on ElectriciansForums
Discuss Cable calc verification please in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Victor
Was France but now Essex
Hi Guys,
Can someone please confirm for me the cable size required
120m length, 63 amps, voltage drop 2%. three phase. Does not have to be SWA.
I think it should be 25mm but would like a second opinion please.
Thanks in advance
Wots your cable method and is that the breaker size 63amp I take its no neutral so you using the neutral for an earth correct and wots the abiant tempter sounds right wot your saying with the lack of info god bless you with the talls and making off the SWA gland when I say use the neutral core as earth please banjo up the outer sheath and strap in down to earth
garbage like that would be more suited to the plumbers' forum, mate.
Seriously, what does this mean???
It's not your technical knowledge that folks are questioning.
It's the fact that you are too lazy and dis-respectful to even bother trying to post legibly.
If you have genuine problems reading and writing then I believe that there is software that can help.
Reply to Cable calc verification please in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If your using 35mm or 50mm use 2 core SWA and use the armour as the earth, it'll cut down on price. I know people will comment on this but the...
Thank you for the advice; I did figure it would be in the realms of discovering, say, a 10mm earth cable in a property, and having no more...
