Cable Calculations for Thermal Insulation Passing Through 2 Points. | on ElectriciansForums
Discuss Cable Calculations for Thermal Insulation Passing Through 2 Points. in the USA Electrical Forum area at ElectriciansForums.net
Reply to Cable Calculations for Thermal Insulation Passing Through 2 Points. in the USA Electrical Forum area at ElectriciansForums.net
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
