Cable choising help need | on ElectriciansForums
Discuss Cable choising help need in the UK Electrical Forum area at ElectriciansForums.net
Jack
Hi I look for advice. What max small size of cable put to 20W 230V LED lamp transformer? 4M long. Thanks
But why do you want a max size when 0.5mm is all that is required (using a 3a fuse in the plug)?
If you are classing this cable as a Power Cable then then min cable size is 0.75mm flex cable, according to table 52.3
Reply to Cable choising help need in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
Please use the like button to thank, like or whatever. As the forum treats that as a positive message then and uses it to score members.
    • Optimistic
Job interview View: https://www.youtube.com/watch?v=uYKD1j5jEvs
