Hi There
Just a quick one, I'm wondering what's everyone's thoughts on this are.
A subby has clipped a cable to a plaster board ceiling using 3m sticky pads and plastic cable ties, below that ceiling is a number of steel beams spanning the length of the corridor and then below them is a suspended ceiling,
we have had the client come back saying this is not compliant, I understand the spark should of used fire rated fixings such as bandit wire or even put a basket up to secure cabling but is it stated anywhere a certain distance apart fire rated fixings should be or is there anything in the regs book regarding fire rating fixings above beams? my thought process is if there is a fire that the cable will drop on to the beams.
Any help appreciated
Thanks Dan
Thanks Dan
