cable codes | on ElectriciansForums
Discuss cable codes in the Australia area at ElectriciansForums.net
[ElectriciansForums.net] cable codes
When i tapped that code in,it came up with this.It says it's a european connection.Still:confused:
Reply to cable codes in the Australia area at ElectriciansForums.net
True. Although I'd hazard a guess that things like woodworm treatment are probably chemically quite similar? Don't know.
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
