C
Crosswire
OK boffins, help me out ........
Called to job where there was no bonding to main incoming gas to a block of flats, and the client required bonding to be installed.
I knew it had to be large, so consulted table 54.8 in order to size it, based on the size of the neutral. Which led me to my problem.......
How do I size the neutral?
This is what I did : opened 3 phase busbar chamber and wrapped a piece of string around the neutral, then measured the string. It was 90mm, which I took to be the circumfrence of the cable (including insulation).
Thinking back to my school days (ok I looked it up) I found these formulas:
circumference = pi X diameter
area = pi r2
Therefore I could find the area of the circle, and presumably the csa of the neutral. So (transposing the formula) 90/ 3.14 = 28.66
The diameter is 28.66 , so the radius is 14.33
so the area is 3.14 x 14.33 squared
3.14 x 205. 3489 = 644.795 !!!!
Now I'm pretty sure the csa of the cable isn't 644mm ! ( Looked more like 70mm) Where have I ballsed it up?
Anyone ?
area = pi r2
Anyone ?
