Discuss Cable diameter in the Electrician Talk | All Countries area at ElectriciansForums.net
I can specify the voltage, which is 380-415V 3-Phase. Unarmoured, In a pipe.there are online calculators for this,
crucially you will need to specify the current in Amps an the distance exactly (or use worst case distance)
you will also need ambient temperature, method of installation i.e. direct in ground, in a pipe (duct) or in free air/
Reply to Cable diameter in the Electrician Talk | All Countries area at ElectriciansForums.net
