cable ducting without pulling rope installed | on ElectriciansForums
Discuss cable ducting without pulling rope installed in the UK Electrical Forum area at ElectriciansForums.net
Wolverhampton
Hi,
Just wandering what to use to get an armoured through a new duct which has been installed prior to me being on site without a pull rope.
Longest run is about 30 meters with probably 2 bends and is about 3 inch diameter but is the flexible type with ridges.
Will rods go that far and round bends especially with it being the ridged type of duct?
I have seen the continuous rod on a reel that bt etc use, is this my only option to hire one and are they flexible enough etc to go round bends of this size etc?
30 meters is pushing your luck especially with corrugated wall ducting. You could try but you'd need to use an end attachment that looks like an egg whisk.
[ElectriciansForums.net] cable ducting without pulling rope installed
What you need is a VERY strong vacuum, some light string, a mate to let it out and a load of patience - I've done it, then pulled through a heavier string, before move on to the cable, HOWEVER in your case the bends and length may make it a no,no!
Something that's worked for us on more than one occasion is using two sets of rods, one from each end. On one side you use the egg whisk attachment and on the other you have a hook. The theory being when they meet in the middle the rod from one side hooks onto the rod from the other side.
I have had the same issues before and with several bends , I tried all sorts with no success , I was told about a pump tape and it worked really well , that was back in the 80s on riser renewals in blocks of flats over long distances too..
Seen a video on social media lately with a guy using the same method but using an inflated condom as a lead bung tied to the string to fill the duct up for maximum suction.
Reply to cable ducting without pulling rope installed in the UK Electrical Forum area at ElectriciansForums.net
