H
hughesy
strange one this guys.just installed some downlights but when i drilled through the plasterboard i noticed half way through i was hitting a cable of some sort and very fine wire mesh the cable core was silver like aluminium it was a single core with black sheath and was 4.0mm solid strand tested it ,it was dead nothing tripped on the rcd board either, the wire mesh also running through the plaster board was very fine 0.1mm, there were 2 of the black cables that i came across could of been more but the ( single core double insulated black cable )and the (wire mesh )were in the plaster board as if it has been embedded by the manufacturer does anyone know what it is or have you seen this before. thanks guys.
