- Joined
- Jan 21, 2011
- Messages
- 581
- Reaction score
- 34
hello there
just a simple one
have a customer wants a lantern fitted to existing wiring to replace old light, does not want any redecoration. old light is fed from wire running down from soffit surface mounted. Now lanterns are designed for a rear cable entry through the wall. just wondered how people go about solving this little dilema.
( my current solution)
i usually run the cable to a morter joint in the brick near the mounting point of the light and channel out the mortar and then feed the cable into the light from the rear enabling the lantern fitting to fit flush to the wall.Making sure that the cable grommit has a water tight seal. any better ideas would be welcome
many thanks
just a simple one
many thanks
