Cable fault location meters , anyone used them before ? | on ElectriciansForums
Discuss Cable fault location meters , anyone used them before ? in the UK Electrical Forum area at ElectriciansForums.net
JD6400
Mentor
We had a break down call out on Thursday to a stable yard we have just completed , it turned out that the 500m 95mm three phase sub main that was installed as a single phase for the time being until they can afford a three phase meter upgrade has been compromised on the currently used brown phase and also on the black phase which is dormant at the moment !
The grey phase and neutral bell out fine .
So we have got the yard up and running at the moment , but we need to go back and locate the problem now !
Have any other forum members had dealings with cable fault location gear and can you recommend which is best ?
We have been quoted around ÂŁ550 + to hire some , but i always prefer to look at buying reconditioned kit at a all be it higher cost rather than pay a dead loss hire fee .
It would not be so bad but the run was moled under two private tarmac roads and strait across the main access yard and lorry park park for the whole complex , without being ducted ( clients request to keep cost down along with using their own labour to lay it ) , BUGGER !!!!!!!!!!!!
Hi Lamb , thanks for the fast reply !
Would this work on a 95mm , have started looking on flee bay for stuff and have come across these but it only seems to mention for telecoms ?
Yes, a TDR will work on any cable that has two cores, eg L1 + N, L3 + SWA etc.
For each cable size/conductor type you need to find the signal transfer rate and set this on the machine.
The machine then tells you the distance (roughly) from the test point to each anomaly in the conductor (cable joint, termination, cable break etc), you then have to interpret the signal to work out where your fault may be.
So if it bounces back 70m, 250m and 500m, and you originally put a joint half way along the run, disregard the 250m (joint) and 500m (termination) and investigate the 70m reading first.
Using a cat and genny find the 70m from test point (will probly be +/- 2m or 3m), dig up and have a look.
Other methods include wheaton bridge but you need a degree to interpret the results (too complicated for me) or old school cut into cable half way, test each half, cut bad section in half again, etc, until you get down to last 20m eg. then just overlay new cable on that section.
Forgot to say, you can also use a cable thumper, again it's specialist to set up, pumps mega volts through the cable at regular intervals, you then walk along the run and listen for the bang as the cable fail point flashes over.
This is the one that we were looking to hire if we can not find anything else , but at ÂŁ550+ it is some what pricey !
TBH by far the best method is common sense - are there any joints in the run, has the ground been disturbed eg other trenches/ demolition works, can be a lot cheaper to ask these questions than hire in specialist equipment and specialists to interpret the results.
Have walked the run and nothing obvious , it only went in a couple of months ago !
My gut feeling is it is at the furthest end of the run through the yard , as the we were not on site when this was back filled and it was some what a hostile environment in that part of the trench !
The black phase has been so badly damaged and because the run is up a fair slope , there is actually water running out of it !
Try it with any low resistance meter. It’s cheaper than hiring equipment. I will admit it’s donkeys years since I’ve used it.
We always had access CAT detectors or if neaded the group engineering pulse reflection gear and the dreaded thumper.
Be warned with a thumper it’s not something to be used unless you’re trained. Last time I had anything to do with one we ended up with two faults, the thumper blew an 11KV joint.
This is what worries me the most Tony , i do not really no what to expect with the thumper and as the owner of the yard is up at the top of his game , there are a lot of very , very expensive four legged friends about that have a bit of a aversion to getting a lick !
Reply to Cable fault location meters , anyone used them before ? in the UK Electrical Forum area at ElectriciansForums.net
