I have a job to do next week putting up 3 exterior lights mounted on the walls of the house. Normally I would wire within the house and pop out straight into the fitting, but certain things are preventing this. The customer wants minimal disruption in the house, so taking up the carpets that are laid on top of glued down lino on top of ply is out the window. Suspect (possibly asbestos ?) ceiling boards above the CU in the garage are begging not to be drilled, so it's been agreed i will wire externally clipped direct to the brickwork. The fittings required are coach lantern type and a small halogen flood. This leads me away from my usual outdoor cable of choice, SWA, as the fittings won't be suitable for cable entry, and I don't think my customer would want glands into galv besa boxes all over the wall.
I have been looking at NYY J/hituf cable as an alternative. I have never used this before and it looks good stuff, but i'm requiring a 5 core cable and don't know whether it will end up being a bit bulky or not.
Is there anything stopping me using flex ? A quick sniff round the web shows some places selling "outdoor" flex that has the same BS6500 category as normal flex. I'm obviously mindfull of UV and weathering effects, will flex cut the mustard here ?
Mechanical resistance is not much of an issue as the flex will be pinned up and out of the way.
Any help appreciated guys :smilewinkgrin:
