cable markings for our own use | on ElectriciansForums
Discuss cable markings for our own use in the UK Electrical Forum area at ElectriciansForums.net
Island dweller lol
When I was serving my time the firm I was with marked the cables cut with a point for a main an angle for a switch wire and straight for a light. What markings do you use if any ? It was and is great and I still use them every day and have added marking a star for a stat and for underfloor a cut 1 2 3 and a star so I can tell which room is which.
At a ceiling rose if I don't have twin brown (weapon of choice for switches) the switch gets a nick. At a multi gand switch they get nicked 1 2 3 etc. If I'm working with more than one circuit using the same CSA cables I too use the CD/DVD marker pen.
It's the way forward
surely twin brown is a pain and time consuming to bell out? No sleeving is no biggie, but you know I always do it. Now do you all sleeve the entire conductor or put a 10-20mm piece on?
As for markings, mains in/out nothing, one straight nick for switch, or two if two gang.
Black is switched live/ keyswitch too!
Why would you bell it out? Strip it at the ceiling rose, one into permanant live bar the other into the switched live terminal. At the 1g sw one into the top one into the bottom. 2w one to L1 one to L2.
Don't you get your switches upside down?
Also, I'm coming from the angle of wiring to or 3 plating at, the switch, so kinda more important then.
No the switches work exactly the same way mate, think about it, whether the live is at the top or bottom or L1/L2 the switch still makes and breaks the same way.
I'd not thought about three plating at the switch, I'm a dinosaur who likes that at roses/fittings:)
In a one gang switch, if you put live in L1, and switch in common, and fix it back to the wall with the 'Top' marking at the 'Top', the switch will be upside down.
no it won't. whichever way round you wire it , as long as you use C and L1, it will be right. however, i always wire L to common and s/l to L1. and i mark my cables in my own way so, should i fall out with the customer, let the next guy work it out.
Reply to cable markings for our own use in the UK Electrical Forum area at ElectriciansForums.net
The wire can't go under laminate. And on top of concrete you need insulation boards (just xpf boards can go as thin as 6mm over here). Otherwise...
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
