Cable method for sumerhouse power | Page 2 | on ElectriciansForums
Discuss Cable method for sumerhouse power in the UK Electrical Forum area at ElectriciansForums.net
manchester
Hi guys,
I'm just looking over a job putting power to a summer house but am wondering if anyone has any recommendations on how to lay the cable.
The cable length from the house is 50M going up the house side wall, across a patio, up a 10m wall (onto a balcony garden) then across a balcony garden (through shrubbery and banking up at a 40 degree gradient) to the summer house. The garden is open to the neighbours gardens (so potential trip hazzard / eye sore) and there is a tree in the direct path of the cable meaning roots (so no trench).
I see 3 options: swa on cable tray on posts, t&e in rigid metal conduit on posts, t&e in flexible metal conduit on posts
If anyone has done similar and has an opinion would be appreciated?
The left had side of the property looks like it would be a ball-ache to do something with the cable, once you get to the top of the stairs. All being open to next doors garden, SWA clipped to posts will look shoddy.
Is there a route on the right hand side?
I see a fence at the back of the shed and a bust line on the right hand side. Is there a fence or is that open to the neighbours on the right?
Yes the run would be longer if you went on the right hand side.
What load are they looking at having?
Can I just clarify something..... In my post above I meant to put 'bush line' not 'bust line'... even though the latter sounds better to have in your garden....
Reply to Cable method for sumerhouse power in the UK Electrical Forum area at ElectriciansForums.net
This charger doesn't support rear entry from the looks, only bottom entry, hence that. Unless they make a white sheathed SWA, I would still need...
