W
wade88
Morning guys,
Preparing to be shot down here, but im a little confused regarding a MCB rating on a piece of machinery at work.
Due to ongoing engineering projects that are taking place, i need to move on machine 15 ft or so furhter down the warehouse to free up space for some new ones coming in. The machine was installed before i began working here so i was not present to witness the install. The machine is rated @ 18.25KW's and is 3p, 415v. So i would have expected this machine to be on a 50amp breaker, but its on a C type 20 and has been wired with 6mm SWA.
If its only running on a 20amp then surely i dont need to buy anymore 6mm at cost to wire it back in, some 2.5 would suffice happily.
My knowledge of industrial controls and machinery is limited but slowly increasing, but is there something im unaware of with this type of machine. To the best of my descriptive powers, The machine is in two parts, a heated 500 litre capacity mixing vessel, with three band heaters run in zones around its circumference, a 1hp motor (0.75kw) so neglegible in the grand scale of things. This machine is then linked to a thermo regulator panel and control box for want of better terminology, that control the speed, temperature and which bands are on or off at any given time via switch control. i have recently replaced the inverter in this module and serviced the Omron control inside and re programmed it.
Apologies is anything i have said is total Bull, like i said, limited knowledge so doing my best to explain.
Long and short is, if its only on a 20amp now and running ok, then there really is no need for 6mm SWA and a 32amp commando to plug into?
Thanks chaps
Ben
Thanks chaps
Ben
